08 F250 MPG question
2008 f250 ClubCab, 4x4 3.73 rear, auto, FX4 model. 5.4L V8
Are the average miles per gallon meters correct? The miles to empty gauge seems to be all over? Also I am going to run the truck down as low as I can in fuel, I am about 3/4 or so it says through a tank and i have only went 160 miles. Is the fuel economy that bad in these vehicles? I drive pretty conservatively mostly been around town lately. My tank is 30 Gallons. If the gauge is accurate then my range is roughly 210-215 miles to a tank. I'm sure I did the math correctly. Does anyone else have this issue? Could the gauge be floating? Could there be a computer problem or something else causing terrible mileage. If my math is right then that means my range is about 210-220 miles to a tank? Does the gauge float? If this mileage is correct..could it be computer problem? Also it says a steady 8.4 MPG in the dash now that I am lower on fuel... Not to sure whats going on...any advice would help. Loving the forum.
mattlikeshockey
12-02-2005 01:08 PM
