1985 F250, fuel delivery problem
Old 01-15-2022 | 05:02 PM
chuckd86000's Avatar
Good point, thanks. I dropped the tank today and it was surprisingly clean and the fuel sending unit looks nice but doesn't work. I measured the voltage that is being applied to the pump inside the tank when the rear tank is selected at 11.5 volts, I think there is a small voltage drop across the contacts of the relay, inertia switch and tank selector switch. I attached the pump directly to the battery, and it doesn't run. I also verified that when I manually move the float to the full position, the gauge reads empty, and when I move it to the empty position, it reads full. This is pretty odd, since both tanks operate this way.....
  #12
Old 01-15-2022 | 05:25 PM
Well, looks like someone put the wrong sender unit in, as described in this thread;
https://www.ford-trucks.com/forums/1...backwards.html
So, should be an easy fix, I needed to replace the sender unit anyways.
Tinbender
10-24-2018 10:14 AM
old_stoney
08-26-2013 12:49 PM
Stapuph
09-23-2010 10:13 AM
digby
03-19-2009 05:08 PM
grumpydave
01-18-2008 04:15 PM
