1985 F250 headlight question
Old 12-16-2020 | 10:57 AM
ljinnc12's Avatar
Default 1985 F250 headlight question
the headlights go out after being on for 5-10 minutes. Turn the switch off and back on they come back on then back off soon after. Anyone have some ideas what might need replacing?
Old 12-16-2020 | 03:01 PM
Some older years had a circuit breaker inside the headlight sw. It was strictly for the front headlights.
There are a few possibilities that should be checked out before replacing anything..
Check the current drain that the headlamps are using. You will need an amp meter to accomplish this. You need to check both hi and low beam current usage. Hi beam will use more current than low beam. Current drain is in the area of 20-25 amps.
If more , need to determine where partial short is. (Original type headlamps not some others)
If current is within "normal" range , the headlamp switch may need to be replaced.
pythonwill
06-11-2013 08:42 AM
red diesel
08-11-2011 04:44 PM
woreout88
11-04-2008 04:31 AM
STEVE1103
04-14-2007 10:01 AM
daddio360
06-13-2006 07:37 PM
Quick Reply: 1985 F250 headlight question
