1989 F250 dying as soon as put in gear
Old 11-20-2022 | 11:53 AM
tommybarlow801's Avatar
Default 1989 F250 dying as soon as put in gear
Starts and idles fine, when I engage D or R it kills. I can sometimes slowly engage and get it to stay in drive and idling or even running but then it eventually kills off. I noticed what seems like the sound of a relay switch and the check engine light comes on- and a slight dip in the voltage gauge. Wondering if that’s connected and if it’s an electrical issue, or if that’s coming on because of what the core issue is. Replaced the IAC valve- didn’t seem to make a difference. Any ideas?
Old 11-21-2022 | 07:02 AM
If your vehicle has the original ignition coil on it, they had internal problems with them.
Might be a good move to replace that since you have no way to prove it may or may not be defective.
Not an expensive item and easy to replace. Let us know if that was the problem cause, thanks.
Madmardigan
07-06-2010 07:57 PM
Asian
06-16-2010 08:15 AM
a_cmc_2b
02-06-2008 09:47 PM
phone
10-11-2007 01:28 PM
radmad
05-04-2006 08:55 PM
Quick Reply: 1989 F250 dying as soon as put in gear
