Ford F-250 & Ford F-350The heavier duty full sized trucks from Ford, offering bigger, more powerful engines and drivetrains for the abuse they may go through in the workplace.
F-250 7.3l 4x4 240k miles,
Replaced the switch in shifter, does not "blink" to incate code. Push OD button, remains "OFF", cannot get OD, need pointed in a direction.
Ya, but I can not pin-point which one it would be. The pannel inside doesn't show a OD fuse and fuse pack under the hood is also unclear which fuse or relay it would be.
I realy dont know if you have a owners manual it will tell you.[hr] Or you can buy a repair book for your truck from an auto parts store.[hr] Or mabey pull the fuse's 1 by 1 and see if they blown.
