1993 F250 7.3 IDI as first vehicle?
Old 12-21-2020 | 03:52 PM
7.Tree IDI's Avatar
Question 1993 F250 7.3 IDI as first vehicle?
Hi, I'm currently looking for my first truck, I have my mind set on buying a good ol' 7.3 IDI. The reason I'm set on getting an IDI is because parts (Like injectors) are cheaper than the newer more powerful diesels (think its $75 compared to $250+ per injector), the cost of ownership is cheaper and they are much, much easier to work on due to less electronics. And why a diesel? No ignition system to maintain and FUEL MILEAGE is my big thing. Don't want to pay stupid fuel prices then get only 13-14 MPG on say a 302W ford. Where I live, In Ontario those old IDIs are hard to come by, especially the ones that aren't rusted right out but parts are easy to come by for that reason (motor for $700 and tranny for $800). Anyways, I found a 1993 f250, extended cab long box truck on kijiji for $5500, it has 360,000kms, has some rust in the non important spots, has the typical cracked dash but all around seems alright. The only problem with it is the windshield is cracked (how much would to cost for a new one?), one window wont go down which I can fix but the big kicker is that its in limp mode. There is no codes or check engine lights BUT its an automatic with the E4OD tranny I believe so the issue is that it will barely move unless you manually shift it into gear. The owner claims it just needs a new tachometer sensor as the tach doesn't work and I guess the tranny needs the tach sensor to work, is this true? just don't want to buy this thing thinking the tranny sensor will fix it and come to find it needs a new tranny altogether. I haven't gone to look at this thing yet, and its a good sistance away so I just want some answers before I take the guys word for it and possibly make a mistake.
Thanks in advance!
Jours
11-22-2019 10:47 AM
low96hb
10-20-2008 06:06 AM
drshancock
02-03-2008 02:37 AM
knapikmichael
11-22-2006 08:51 PM
Knyghtlander
06-19-2005 05:13 AM
Quick Reply: 1993 F250 7.3 IDI as first vehicle?
