1994 Ford 7.5 liter Gas, OBD I code 538
Old 08-22-2008 | 11:47 PM
Tboy's Avatar
Default 1994 Ford 7.5 liter Gas, OBD I code 538
I have a 1994 Ford 7.5 liter Gas engine, and I have OBD I code 538. "Insufficient RPM change during KOER Dynamic Response Test". What does this actually mean? Do I need to fix it? If so, how? The engine runs well unless it is over like 95 degrees and it is run hard, then when I slow down, it sputters and backfires until I either let it cool, or get it back to highway speed.
Any help would be appreciated, thanks.
Old 08-23-2008 | 10:46 AM
Default RE: 1994 Ford 7.5 liter Gas, OBD I code 538
During the KOER self test, the PCM commands the IAC (idle air control motor) to raise the engine RPM to the desired/calibrated speed.. If the engine speed isn't met you'll get a insufficient speed code.. Most times it's an issue with the IAC being restricted/clogged, sticking, or failing.. Without the IAC working in conjunction with the PCM commands, idle stability as well driveability to a degree can be a problem..
[IMG]local://upfiles/6756/B7D9726666DD4AAAAA14015CA14A59D0.gif[/IMG]
ups88
01-18-2010 01:34 PM
bill9iron
08-15-2007 08:47 PM
berbaby
01-12-2007 07:38 PM
revidffum69
08-30-2004 10:13 PM
