2001 250 7.3
RE: 2001 250 7.3
There isn't a Schrader valve on the later build 7.3's SD.. It's a 'return to tank' system.. Although there is a fuel filter/water seperator drain, and a plug in the canister/forward to install a test gauge, and a 1/8 pipe plug at the end of the cylinder heads to test pressure/volume..
Whats the concern for air in fuel?
cat5656
06-29-2011 02:44 PM
