2001 7.3 repair manual
Old 10-09-2007 | 07:03 PM
dieselvic's Avatar
Default 2001 7.3 repair manual
I also wanted to know where i could find an online maual for the 7.3 i bought the truck a couple of months ago
so far i have'nt had the best experience also is it normal to get only 13mpg for the7.3 i thought diesels were
good on fuel
Old 10-09-2007 | 07:15 PM
david paul's Avatar
Default RE: 2001 7.3 repair manual
I BOUGHT MINE ON EBAY FUEL MILAGE DEPENDS ON GEAR RATIO DRIVEING HABITS SEVERAL DIFFERENT FACTORS MAY NEED DIFFERENT CHIP LARGER AFTERMARKET EXHAUST MINE IS A 94 7.3 TURBO CREW CAB 4X4 WITH3:55 GEAR AND I GET 16MPG SO I WOULD THINK U SHOULD GET AROUND 18 MPG SOME ONE ELSE MIGHT HAVE MORE IN PUT AS I DON'T WANT ANTHING NEWER THAN A 94 AS I CAN STILL WORK ON THESE
Old 10-09-2007 | 07:44 PM
dieselvic's Avatar
thanks for the info the only thing i've noticed is a larger exhaust i passed inspection so i don't think there is a chip and i get on it once in a while i changed the fuel and air filter and there was still no change
Aquakittie
12-07-2012 11:17 PM
cg
01-12-2007 04:18 AM
Jville808
10-21-2006 11:49 PM
chaumer
02-20-2006 03:05 AM
DOC
02-07-2006 01:02 PM
