2001 f250 5.4l won’t run
Old 04-20-2021 | 08:12 PM
Trizz5253's Avatar
Default 2001 f250 5.4l won’t run
The other night my wife got into my truck and turned the key and half started the truck and let off of the key before it fully started. It made a weird noise and started to smoke(not electrical) but oil or coolant but very lightly. After that I tried to start it and when I do it will start immediately rev to 2-2500rpm and drop right back down and die. If I keep it above 3k rpm seems to run smooth. Any ideas where I should start?
Old 04-21-2021 | 05:04 AM
raski's Avatar
Check for codes. I would believe it would barely run if the timing chain jumped but is a possibility under that situation.
Old 04-21-2021 | 09:10 AM
Might be a good idea to look for a vacuum hose that got blown off at the time it pushed back.
mrking22
03-12-2013 05:38 PM
mayor
11-18-2012 06:46 PM
mkscw
12-03-2010 02:47 PM
fomoco74
02-26-2008 09:56 PM
kenpage
03-09-2006 03:29 AM
Quick Reply: 2001 f250 5.4l won’t run
