2003 f250 4x4 missing front driveshaft
Old 11-27-2022 | 02:19 PM
Watsoncopier's Avatar
Default 2003 f250 4x4 missing front driveshaft
i just got this truck and the front driveshaft is missing. Will the shaft out of an 06/07 f-250 work? It has 5.4 gas engine
Old 11-27-2022 | 04:31 PM
As far as the slip yoke and number if splines, not sure, but what you can do is measure the distance from the pinion flange to the transfer case flange ,,. It they are the same it should work.
Old 11-27-2022 | 06:41 PM
Thank you so very much. I will measure when i get off work. I truly appreciate your response.
Ahaarm17
12-29-2021 11:19 AM
Stephen Gully
12-07-2018 02:25 PM
foxthetrot
12-16-2016 10:24 AM
gashogf250
05-14-2007 08:13 PM
Mr_furiouss
04-18-2007 08:02 AM
Quick Reply: 2003 f250 4x4 missing front driveshaft
