2003 f350 headlights dont work???????????
Old 12-11-2007 | 08:44 AM
broncocarnage's Avatar
Default 2003 f350 headlights dont work???????????
i have an 03 f350 and my headlights do not work but yet all the fuses are good pls help me.
Old 12-11-2007 | 08:46 AM
Default RE: 2003 f350 headlights dont work???????????
i have replaced the switch too
Old 12-11-2007 | 12:07 PM
Make sure the fuse F2.7/30amp in the CJB is good.. It supplies power distribution to the headlight switch/multi function switch.. Power feed 'out' of the H/L switch into the multi function switch is the RD/YE wire.. Headlight fuses in the CJB are...F2.30 for low beam, and F2.46 & 47 for high beam... Check for both lamp functions as well as flash to pass.. Chances are it's the multi function switch if all the fuses, bulbs, groundsare good.. But check for current 'through' the headlight switch (DB/OG in, RD/YE out) down to the multi function switch on connector (RD/YE).. With the multifunction switching headlamp functions L/H, the power should jump/switch from the GY/OG (high beam), and to RD/BK for ther lows..
sittingmonkey
03-11-2009 08:47 PM
simpson110
12-08-2008 08:29 PM
Trester
11-30-2007 07:06 PM
chinomedic
07-22-2007 12:30 PM
chinomedic
07-19-2007 03:19 PM
Quick Reply: 2003 f350 headlights dont work???????????
