2004 Ford F250 Door
2004 Ford F250 Door
Hello, I have a 2004 Ford F250 Crew Cab 4x4 6.0 Diesel. I have a slight wind noise coming from only the front pasenger door. Is there any way to seal this up better? Is there a way to adjust the door or the mirror to help this? Thanks in advnace.
RE: 2004 Ford F250 Door
Generally the crew doors are pretty wind tight.. Does it still whistle if the mirror is folded in? Antenna/wipers ect.. Might check the complete door weather strip as well as the lowersplash trim for fit.. The door striker can be adjusted in to pull the door in a little tighter, but if the outer portion of the door shells line up straight at the body line, usually their adjusted.. With a passenger, can they tell if the noise is high/low to the door?
2004, adjust, adjusting, adjustment, cab, car, crew, door, expedition, f250, ford, fordf250door, noise, posts, striker, weatherstripping, wind
