2005 F-350 Super Duty front suspension torque specs
I'm changing ball joints, tie rod ends, shocks, steering damper and track bar on my 2005 F-350 4X4. 6 liter dually. Looking for torque specifications for all the values associated with this job. Any good sources out there ?
Welcome to the site..
Description Nm lb-ft lb-in
Front driveshaft-to-pinion flange bolts 102 76
Front shock absorber-to-frame nut 63 46
Front shock absorber-to-shock absorber bracket bolt 150 111
Hub lock screw 6 Nm— 53 (lb/In)
Jounce bumper-to-frame nut 35 26
Lower ball joint nut 204 150
Radius arm-to-axle bolts 300 222
Radius arm-to-bracket nut 300 222
Stabilizer bar link-to-axle nut 80 59
Stabilizer bar link-to-stabilizer bar nut 150 111
Stabilizer bar retainer-to-frame bolts 48 35
Tie-rod end sleeve adjuster nuts 55 41
Tie-rod end-to-knuckle nut 115 85
Track bar bracket-to-frame nuts and bolts 175 129
Track bar-to-axle nut 250 185
Track bar-to-track bar bracket bolt 550 406
Wheel extension nut 176 130
Wheel hub assembly nuts 180 133
Wheel speed sensor bolt 18 13
Adjusting sleeve nuts 55 41
Adjusting sleeve bracket nut 18 13
Damper nuts (4x2) 80 59
Damper-to-bracket (F-250, F-350 4x4) 35 26
Damper-to-drag link (4x4) 90 67
Drag link-to-pitman arm nut 200 148
Inner tie-rod end nut (F-250, F-350 4x2) 115 85
Outer tie-rod end nuts 115 85
Sector shaft arm nut 475 350
Track bar bracket-to-frame bolts 175 129
Track bar bracket-to-frame nuts 175 129
Axle nut??
Installation...
Installation...
- Install the camber adjuster sleeve.
- Position the wheel knuckle onto the axle and install the nut onto the upper ball joint. Do not tighten the nut at this time.
- Apply threadlock and sealer to the threads of the lower ball joint and install the nut onto the lower ball joint. Do not tighten the nut at this time.
- Tighten the lower ball joint nut to 59 Nm (44 lb-ft).
- NOTE: Do not loosen the nut to install the cotter pin.
Tighten the upper ball joint nut to 94 Nm (69 lb-ft) and install the cotter pin.- If necessary, tighten the nut until the cotter pin can be installed.
- Tighten the lower ball joint nut to 204 Nm (150 lb-ft).
phantasm94
04-23-2019 03:04 PM
Anderson Nick
03-30-2019 01:33 AM
