2006 F-350 5.4 crank no start
Hello! I've got a slew of issues on my 06 F-350, primarily being it cranks but no start. I have spark, my scanner shows I have 8.6 bar of fuel pressure (that's pretty high I think?)
Let me preface this with I'm a GM guy, I don't know SQUAT about Fords, I'm sure it's easy to pick up but I just don't want to dive into something I don't know without doing some research.
When I got this truck, the timing chain has been extra rattly, and has stalled at low speeds in drive/reverse.
It has a plow, I put it on to test it before winter and decided to push some wood chips around to get the massive pile scaled down.
As I was ramming into it like I would plowing, it did it's reverse stall. I tried to crank it and nothing. I saw the battery came loose and had a hole poked in it., so I replaced it and put a better hold-down on it. Now it cranks, but doesn't start. I tried to press the fuel cutoff breaker in the passenger foot well, but no change. I tested positive for spark on all 8 cylinders. My scanner says I have 8.6? bar of fuel pressure, but the pump kicks on very quietly for less than a second. It ran on ether but I don't want to put any into it because it's a gasser and it sounded like a blown 6.5 when I used it. It also is throwing P0201-P0208 (injectors 1-8) codes.
TLDR;
Stalled, has spark, no fuel, fuel breaker wasn't tripped. Runs on ether. Don't know what to do.
TLDR;
