2016 dead f-250 died, engine overtemp, pressure monitor fault, servoce advance trac,
Old 05-03-2021 | 06:20 AM
rkreveg's Avatar
Default 2016 dead f-250 died, engine overtemp, pressure monitor fault, servoce advance trac,
My 2016, 6.2L gas truck all of a sudden went haywire. It completely died and won't start. When I turn the key on I get all types of system warning problems on the screen:.( engine overtemp, pressure monitor fault, service advance trac, starting system fault, the wrench icon). Then when I try to start the truck, everything goes dead. I've checked the ground wires and am not getting anything to the starter. Anyone have any ideas?
Old 05-03-2021 | 11:34 AM
Suppose we start at the beginning.
Some security systems will not allow the starter to operate if there is a problem , like the key for example.
To eliminate that possibility, try your second key and see if that allows the starter to operate.
When we get a series of codes that are not related, that can be a grounding connection problem.
Don't have any idea of the condition of battery or wire connections of your vehicle, but if not clean and in good condition, system cannot function correctly due to insufficient power supply. Grounding is the other half of the circuit.
Michael Patterson
12-26-2019 09:22 AM
Taylor Jones Laws
08-10-2019 11:22 AM
Armando Garcia
08-09-2019 09:58 PM
Dave Anthony
08-09-2019 01:33 PM
cmd242
12-24-2018 03:01 AM
Quick Reply: 2016 dead f-250 died, engine overtemp, pressure monitor fault, servoce advance trac,
