2017 Ford F250 Lariat
This has happened twice in the last week in the am. Seat memory and Steering wheel tilt not working. Everything else works. First time it happened it was ok in the afternoon. Just happened again this am. Will see if it is ok later. Called two dealers locally and both never heard of this. I can't believe this that this has never happened and no dealer is aware of this. Any thoughts by anyone? Don't believe its the fuse as if it was would not be working again.
It could be something entirely new.
What is usually needed at this point is a wiring diagram to see what circuits or grounds these two features share. That might provide some direction to start looking..
Otherwise you may need to have someone with the info and background check it .
Firefitr83ml
11-08-2018 06:12 AM
