2019 F350 passenger floor wet
Old 07-16-2024 | 11:03 AM
turk10315's Avatar
Default 2019 F350 passenger floor wet
Water is getting under the floor mat on the front passenger side. Doesn't smell like antifreeze. Trying nto figure out where the drain is to see if its clogged. Pics would be great along with typed instructions. Thank you!!.
Old 07-16-2024 | 02:46 PM
Does your vehicle have air conditioning and are you using it ? If so, check the drain under the passenger side firewall in the engine compartment.
Old 07-17-2024 | 05:37 AM
turk10315's Avatar
I have been looking for that drain but am unable to locate it. Any pics of what I should be looking for? Thank you.
Old 07-17-2024 | 06:31 AM
I cannot come up with a pix, but the rubber membrane runs from the driver's side to the passenger side and is located just under where the air conditioning lines enter the inside of the vehicle. It has a tendency to stick closed and all it usually takes is to flex the end so it can open and drain the condensate from the inside of the vehicle.
When it is working properly, you will usually see water dripping from the underside of the vehicle when parked when the air conditioning is being used.
nofishissafe@att.net
09-08-2024 04:33 PM
kevin123
07-21-2022 10:25 AM
RT58
10-17-2021 08:23 PM
Jbell
12-04-2017 12:50 PM
mobetterz
09-14-2011 11:32 AM
Quick Reply: 2019 F350 passenger floor wet
