390 2v to 4v
Old 02-11-2008 | 03:26 PM
stewart390's Avatar
Default RE: 390 2v to 4v
its a 400
  #12
Old 02-12-2008 | 07:07 PM
bauer123's Avatar
auto or manuel trasmission?
  #13
Old 02-13-2008 | 03:39 PM
stewart390's Avatar
auto
  #14
Old 02-13-2008 | 06:42 PM
bauer123's Avatar
Cool I know you have a fe motor. But this an easy swap for a 429/460. the 429/460 will bolt up to the transmission that is in the truck now. You need the spacer between the engine and transmission for a 429/460. motor mounts you can get aftermarket. ie trans adapt or k&l conversions. Also if you want you can use lincoln 1976/1977 that had a 429. mount rh to lh side and lh to rh. the stud holes in the frame mounts have to be notched 1/4 inch down. You can use the stock radiator. i matched up hoses at napa. The fe motor will not bolt up to the transmission. ie diff bolt pattern. Also no motor mounts aftermarket. I had a 1977 ford truck i did. Best truck i ever had this thing would tow a tank. Sorry i ever sold it. I have also done this for six other customers. If money is not an issue. there are lots of cool parts for 429/460 motors. ie 514,540,572. I have built two 540 motors 650hp 500fpt on pump gas. One was efi. in town mileage ave 11 to 15. towing 8 to 10. this motor now has 25,250 miles on it.
  #15
Old 02-16-2008 | 01:46 PM
stewart390's Avatar
dang sounds like an awesome truck . I gave up on the 78 the guy wouldn't go below 800 for just the body and frame so i started looking aroung and came across a 76 and that will bolt straight in and he only wants 1500 and it runs so im going to go look at it tommorrow the body is a lil rougher but no real rust except in the bed which i'll just weld a new spot and spray . this is a 250 also he says it has heavier axles but when i asked him he had no idea what they were so i assume the are still 40 60 . I paln on still running the 390 thats in it while i rebuild the 390 that i have sitting around . i have the money to put 44's on it and thats what i plan to do but doubt i'll get to it till next year
pilotjock
09-01-2007 12:10 PM
truckinmanNga
07-29-2007 04:59 PM
enginess
06-25-2007 06:23 PM
mustang50racers
01-16-2007 12:55 AM
evil_redneck
03-23-2006 10:19 PM
Quick Reply: 390 2v to 4v
