44single to daulie wheel conversion
Old 11-19-2007 | 05:50 PM
davishenry's Avatar
Default 44single to daulie wheel conversion
I need to convert an 1984 F350 4X4 pick up to dualie wheels front and back. Does anyone know what would be required in the front regarding spindles, hubs, etc. as a dualie wheel on the front may set too far in? HD
Old 11-19-2007 | 06:22 PM
david paul's Avatar
Default RE: 44single to daulie wheel conversion
i know the front uses a hub extension and i think the rear dose also because the inside tire would probably rub the springs u can get conversion kits but i would try at a salvage yard would probably be cheaper
Old 11-19-2007 | 06:40 PM
davishenry's Avatar
.... and 2 wheel drive and 4 wheel drive would be different I guess? thanks H
Old 11-19-2007 | 06:58 PM
david paul's Avatar
i couldn't say on that as i've only seen them on 4 wheel drive but i would think they would be the same as the lug pattern is the same and the extensions bolt on the lug bolts and then there is lug bolts on the extenisions for the wheels i thing a factory duallie set up will interchange
89formula406
10-22-2012 09:26 PM
Harburmaster
02-16-2009 09:12 PM
broncky
10-08-2007 07:59 PM
broncky
10-08-2007 07:59 PM
jake3020
05-03-2005 01:22 PM
Quick Reply: 44single to daulie wheel conversion
