'93 F250 7.3 diesel starting problems
I have a 93 f250 and whenever it sets for a couple hours and you go to start it again it will start up and start running but then it cuts out like its running out of fuel... i know its not the fuel pump or filter as they are both new ... any ideas???
RE: '93 F250 7.3 diesel starting problems
Sounds like it could be sucking air into the fuel system. Easy way to check this is to install a clear line between fuel filter housing and injector return line. Hang the clear line in a loop to trap air and crank and/or start engine and watch the line to see if you get a large amaount of bubbles in the fuel.
jeff@tortorelli.com
10-04-2011 08:16 PM
teddysmith1952
12-07-2009 10:49 AM
richarddd
08-09-2008 01:07 AM
