93 f250 won't start
Old 05-17-2008 | 09:48 AM
93f250xlt4x4's Avatar
Default 93 f250 won't start
I have a 93 f250 351 5.8 and now it won't start. When I get it to start it runs like hell. When I press the gas it stalls. Even when I don't press the gas the engine stalls after about a minute. I have an msd ignition box. I got it started and now it runs real bad when you press the gas it makes that sound like you ran out of gas.
Old 05-17-2008 | 12:05 PM
jenior71's Avatar
Default RE: 93 f250 won't start
I AM NOT FAMILIAR WITH THE ENGINE ON YOUR TRUCK. IS IT FUEL INJ, WHAT SIZE ETC..
Old 05-17-2008 | 12:22 PM
jenior71's Avatar
WHAT YOU CAN DO IS TRY TO KEEP IT RUNNING AT IDLE AND REMOVE A SPARK PLUG WIRE ONE AT A TIME EITHER FROM THE SPARK PLUG END OR AT THE DISTRIBUTOR. SEE IF THERE IS A CHANGE IN THE ENGINE. USUALLY , WHEN AN ENGINE HAS A REALLY BAD MISS YOU MIGHT HAVE A BAD SPARK PLUG WIRE AND OR A BAD INJECTOR. IF THERE IS A CHANGE AT A CERTAIN PLUG HOLE YOU HAVE NARROWED DOWN THE PROBLEM, BAD WIRE, INJECTOR, LOSS OF COMPRESSION, STUCK OPEN VALVE ETC. YOU HAVE TO START WITH A COMPRESSION TEST AT THE SUSPECT HOLE...IF THERE IS NO REAL CHANGE IN THE IDLE WHEN REMOVING THE SPARK PLUG WIRES THEN CHECK YOUR FUEL PRESSURE. SHOULD BE AROUND 50 TO 60 LBS. COULD BE A BAD FUEL PUMP..HAVE YOU CHECKED YOUR FUEL FILTER. A REAL CLOGGED FILTER WILL CAUSE ALOT OF PROBLEMS ALSO. HOPE THIS HELPS.
liv3wired
01-02-2009 12:07 AM
Seengs
03-31-2008 06:54 PM
6x6man
09-13-2006 05:09 AM
6x6man
04-30-2006 04:10 AM
JAKE065
07-02-2005 03:19 AM
