95 Ford F-250 5.8l looses power and spudders turn it off and crank it back up it runs
Old 06-18-2021 | 06:39 PM
Niclaird10's Avatar
Default 95 Ford F-250 5.8l looses power and spudders turn it off and crank it back up it runs
While driving any speed after a few min it cuts out and spudders and looses speed put in neutral turn it off and crack it back up it runs fine for a few minutes , if given full throttle it does the same , followed another forum and replaced the fuel pressure regulator . No resolution . Truck still has egr and smog pump . Should I chase a fuel problem , previous owner says he replaced rear tank pump with in the last few months and front pump still needs replaced . Any suggestions will help thank you in advance!
Old 06-19-2021 | 06:48 AM
If you replaced the fuel filter, what comes out of it can tell you a lot..
Get hold of a fuel pressure gauge and confirm fuel pressure is not dropping.
If all is well, then you might want to verify the 5 volt reference voltage is not dropping out.
Depending on what you find , we can go from there.
Old 06-20-2021 | 02:55 AM
raski's Avatar
Connect a fuel pressure gauge so you can monitor it while driving. You should have 30-45 psi at all times if your fuel pump is working. Don't mess with the regulator unless it is leaking. It actually keeps the pressure from going too high.
Paul Kennelly
02-11-2019 12:42 PM
Bherbin
02-19-2015 04:54 PM
Crimepuppy
10-27-2009 06:51 AM
ironics00
11-07-2006 09:52 PM
Quick Reply: 95 Ford F-250 5.8l looses power and spudders turn it off and crank it back up it runs
