95 Ford f 250 diesel prob
#11
RE: 95 Ford f 250 diesel prob
CMP is just above the crank pulley, and below the water pump on the right/passenger front.. One bolt/bracket holding it into the cover.. With some basic tools it's a pretty simple job..
[IMG]local://upfiles/6756/D7796788DF1845CE8C0CB19D9D076B3B.gif[/IMG]
#15
OK I replaced the CPS (expensive little booger) and it seemed to be better but it still actsilly with the stalling and acting like it is out of fuel. Going to do a pressure check this weekend. Is there a pre filter I am misisng other than the big fuel filter? It also showed no codes on the reader.
#17
I hope that did it for you rescue man if you need parts for anything else check out my web this is from a ford dealership and everything sold on it is at employee cost. I too was a Firefighter E.M.T. for four years anything I can Do to help.
#18
Cool I am looking to put the right altenator on my truck, there is a 95 amp (I believe) and it will not even carry the load when the headlights are on. It doesn't go totally down but it will dim the headlights, so you can only imagine when the light bar is on.
#20
I am probally going to need the best with running the lightbar and other emergency lights and siren. I don't want to screw up my batteries and the one that is there now really doesn't carry the load well.
