'96 F350 ignition bar?
Old 12-21-2021 | 12:50 PM
PWRmx24's Avatar
Default '96 F350 ignition bar?
When I turn the key the glow plug light doesnt come on, the key goes foward and seems to have less resistance than before, it goes all the way foward and has a small "springy" return but the engine doesnt turn over. I see a small white / yellow plastic bar moving foward a back when we turn the key. Is it perhaps a problem with that mechanism? Ill try to post a video or picture.
Old 12-21-2021 | 01:18 PM
Do any of the gauges come alive when you turn the key on?
If not, I would look under the dash at the lower steering column for the ign sw assy. does anything move there when you turn the key to on or start position?
Old 12-21-2021 | 02:29 PM
PWRmx24's Avatar
Default Movemement
Not sure. Im dissasembling the steering now to see whats going on. Cant upload a video.
i dont see anyhthing moving when i turn the key and look on the underside of the steering column.
Old 12-22-2021 | 08:08 AM
Did you look as far down as next to the brake pedal?
Old 12-22-2021 | 04:56 PM
PWRmx24's Avatar
Default Ignition actuator
Thanks for the r
eply Hanky. The pin on the ignition actuator was out. I got an entirely new ignition actuation just in case. But i cant get it back into the slot. The lower part where the pin goes in is too far down in the slot.
Kyle700
05-04-2016 11:51 AM
Adrescher7
01-25-2012 07:37 PM
Reapr
09-20-2011 09:28 AM
bodyman61
08-15-2009 09:58 PM
ExplorerOnKrome3152
03-11-2007 12:53 AM
Quick Reply: '96 F350 ignition bar?
