97 F350 Where is the: Crankshaft Position Sensor 460 2x4
Old 10-30-2023 | 09:09 PM
DerekWolf's Avatar
Default 97 F350 Where is the: Crankshaft Position Sensor 460 2x4
Hey, I need a bit of help.
My 97 F350 Crankshaft Position Sensor through a code and I want to change it out.
My question is: Where is it located?
Thanks ahead of time for you guys that answer.... means a lot to me.
97 F350, quad cab, dually, 460 engine, 2 wheel drive. 97000 miles as of today.
Derek
Old 10-31-2023 | 08:35 AM
In this case it is called a pick up coil and is located in the distributor which will require removal of the dist to replace it.
Make sure to place crank pulley on TDC before removing dist, makes job easier. Also mark dist and rotor positions before removal makes reinstalling dist correctly easier too.
Devon02
11-27-2021 08:59 PM
Jayinri
01-13-2013 11:00 AM
2ron2dude
02-07-2008 11:07 AM
chev502
09-22-2006 12:20 PM
chaumer
02-20-2006 03:05 AM
