99.5 dimming lights-battery warning
Old 03-24-2007 | 04:53 PM
ranchhorse's Avatar
Default 99.5 dimming lights-battery warning
I have a 99.5 F350 SD 4wd CC DRW 7.3 ltr. The head lights and interior lights dim and the battery light flahes at the same time. Doesn't do it all the time, seems to follow bumps a lot. Sometimes you might go 50-100 miles without any problems. Volt meter readings on both bats and alternator read 14.8 to15.1 range everytime I've checked and I have checked multiple times. Now I'm leaning towards ground problems. The two ground wires bolted to the frame under the bed are tight, otherwise I haven't followed the ground wiring yet. Any ideas??? Thanks for any help, Luke
Old 03-24-2007 | 05:09 PM
goinstrong's Avatar
Default RE: 99.5 dimming lights-battery warning
Look for a loose wire with a cover over it (like on the alternator).
ebillimoria
07-17-2014 12:32 PM
cory71
10-18-2010 08:10 PM
ecwinch
02-25-2009 03:35 PM
xmannyc
06-24-2006 06:51 PM
fdioso713
04-07-2006 03:21 AM
