CB radio install
CB radio install
Finding it hard to find a good place to mount my CB so I used a "saw" mount and it sits on the floor of my F250 (2006), with a bench seat. Can anyone tell me how to wire the power so Idon't get the RPM's from the alternator? Is there any way to reduce the noise?
RE: CB radio install
You can run a coax type cable (RG-59) directly from the battery to the CB. Connet the sheild to the ground - negative and the center wire to the positive at the battery. On the other end at the CB only connect the positive for the powerand cut the sheild back a but and tape it off. You will need to ground the radio to the chassis. This should work to eliminate the engine whine. The bad part is it doesnt shut off when the rig is off so you you could accedentaly leave it on and drain the battery.
boch1165
03-27-2009 11:13 AM
b3n129
09-20-2008 05:59 AM
