Check Engine Light.....
Old 02-07-2009 | 02:36 AM
Blue Meanie's Avatar
Default Check Engine Light.....
Just bought this F250 and noticed that it loves to drink gasoline (more than it should).
Also a couple symptoms are stumbling when I hit the gas hard, and hard starting when cold (a single pump of the accelerator helps).
The check engine light was on as well so I pulled a couple codes from the EEC-IV and they came up with these:
122 - TP sensor circuit below minimum voltage
542 - Fuel pump secondary circuit failure: PCM to ground
What is the best course of action to fix these issues? I was think possibly changing the TPS, but I don't want to chase the problem. I want to fix the problem.
Thanks in advance for the help.
93redxlt
03-18-2010 05:44 PM
allensimpson
01-10-2008 10:40 PM
farris1307
09-09-2005 05:59 PM
basketbjones
08-30-2005 11:16 AM
bluemq1
05-16-2005 09:06 PM
