Clutching problem
Old 04-29-2006 | 08:25 AM
odonnks's Avatar
Default Clutching problem
I did a search and did not find this specific issue.
A have a 1995 F250 Powerstroke, standard shift.
When ever shifting You need to bottom the clutch pedal to the floor to get good engagement and easy up or down shifting.
If you in Neutral, Its very hard to get into reverse. Awlays get taht grinding sound unless you really bottom the pedal out.
Its as if the clutch is not fully disengaging unless its way past the normal clutch travel.
We pull horse trailers with this and ther is no slippage so I ruled out a worn clutch plate.
I've looked and can find no adjustment that would alter the pedal stroke.
Is there something i'm missing?
Thank you
Old 05-20-2006 | 02:31 PM
daddydan's Avatar
Default RE: Clutching problem
i have a 2000 f250 same problem ever since ive had it brother in law 96 f 350 same problem wait till you get into a gridlock situation you will be exhausted pushing this clutch pedal to floor i have found no solution to problem other than switching to automatic
Old 07-14-2010 | 01:57 AM
jayare's Avatar
had an 89 1ton with the same problem it was the firewall was weak and broken the peddle was pushing the firewall out and could hardy get it into gear. had to beef up the fire wall
