Dash Upgrade
Dash Upgrade
OK I Have a 2012 diesel F250 super duty 4x4
Upgraded the dash to a center display and that works!
What I now don't see is 4wd status lights...
If I go to off road I do see icons but they don't seem to reflect 2wd 4wd 4wd L and no dash icons...
Question is there a 2wd dash and a 4wd dash? This seems like a 4wd dash with the off-road but no clue on 4wd status...
are there bulbs for those icons?
thanks in advance for any advice.
Welcome to the site..
Who's center panel? Non OE?
Each vehicle has its own 'as built' data. PCM, BCM, ABS, ICP, APIM, etc. When you make changes like adding Navigation, ACM, various modules etc, generally the as built data/values need to be changed, or in part, a rewrite to activate certain features.
Before moving forward, can you give a better idea of the work performed, and parts used...
