Door Adjar Light stays ON
Old 01-15-2007 | 10:12 PM
ArtFabrk8's Avatar
Default Door Adjar Light stays ON
1999 F250 Super Duty XL; Door Adjar light stays on sometimes as well as the interior light, can't find reason nor how the system and or the switch works or even where it is. A little HELP?
Old 01-15-2007 | 10:38 PM
wheelsup68's Avatar
Default RE: Door Adjar Light stays ON
There have been many recent post on this. You need to get some PB Blaster rust penetrant and thoroughly douse the door latches on both driver and passenger sides. Concentrate your efforts toward the bottom of the latch as this is where the door ajar switch is located and gets stuck. After spraying work the door open and shut a bunch of times and spray more penetrant. After working door latched and unlatched about 50 times see if problem goes away and then sparay with some sort of white lithium grease, and this ought to take care of problem.
livingstonroofsinc
05-31-2012 05:59 AM
DARIN J
07-17-2009 03:35 PM
pats99ranger
02-17-2009 12:25 PM
Zapman
02-16-2009 06:29 PM
pmj4dlg
12-11-2008 06:47 AM
Quick Reply: Door Adjar Light stays ON
