Electrical Problem..HELP!!! ABS Blinking..wont go into gear now
Old 09-25-2008 | 01:37 PM
oberding's Avatar
Default Electrical Problem..HELP!!! ABS Blinking..wont go into gear now
I have a Ford F-250 truck with a 7.3 powerstroke turbo diesel. Recently I was trying to wire a trailor up to the 7 pin connection in the bed of the truck. I had the bare wires from the extension exposed and 2 things happened. First the ground wire ( white wire ) touched the bed and I saw a minor spark, from then on there seemed to be no ground connection when I tested the lights out in the trailor. As the brakes were applied the trailer lights went out all together and same thing with the blinkers. I had the hazard lights on trying to figure out the problem and I think another wire touched the metal bed or something and the blinkers all went out. still had running lights, no blinkers also ABS light flashes and the truck will not go into gear at all!!! Any idea what got burned up and what needs replaced? I checked all the fuses, all looked good. my phone is 435-245-0212 or e-mail is theoberdings@yahoo.com . Any help would be greatly appreciated. Thank you much. Fred Oberding[/align]
whayewkno
02-06-2013 05:20 PM
Bob Lobblaw
04-09-2009 10:00 AM
mrglass39
05-29-2007 09:29 AM
silverT1000
05-03-2007 01:51 PM
danny88
10-29-2006 02:04 PM
Quick Reply: Electrical Problem..HELP!!! ABS Blinking..wont go into gear now
