Electronic Climate Control Head
Here's the problem:
My climate control is electronic and it has no display and is not functioning. This happened once before about a week ago & I checked all the fuses & they were all good. However, it just came back on. I thought maybe one of the fuses was loose.....not the case though.
On another note, I do have a failing ignition switch that thinks the keys are still in the ignition when they aren't. I believe that it's just worn out----didn't know if this would be related, but I thought it was worth mentioning.
Other than that everything else in the truck is working as it should be. I have taken the dash off to verify that both the wiring harnesses are secure & in place. Any help would be appreciated.
Mike
Mike
cceretti
12-13-2009 04:42 PM
