Emergency/parking Brake Adj
I have a 99.5 cc drw 4wd 7.3 6spd. One of the emergency brake cables broke. I have replaced it, but the brakes need adj/tightened. How do you adj the setting? The brakes are not holding at all, pedal almost falls to the floor. Thanks, Luke
RE: Emergency/parking Brake Adj
The park brake adjustment is like a standard drum adjuster.. The E-brake on the S/D's is a 'drum in hat' meaning that the E-brake is a small shoe set in the center of the rotor assembly.. Just remove the backing plate adjuster plug, and rotate the star adjuster until a slight drag is heard..
Here's a pic of the backing plate adjuster hole..
[IMG]local://upfiles/6756/61540FC8BD9842C4963C71F98AF2F586.gif[/IMG]
