F-250 no heat or A/C in cab
Old 06-24-2011 | 11:32 AM
donkersr's Avatar
Default F-250 no heat or A/C in cab
Heater and A/C controls all work, but the temperature of the air blowing through the ductwork is always ambient temperature. A/C lines under the hood get cold (condensation forms) when I turn on A/C controls, so I believe A/C is working. Why can't I get warm or cold air delivered into the cab?
Old 06-24-2011 | 02:33 PM
Gary2Wheels's Avatar
dunno what year truck you have but vacuum motors control the flow,I believe.A friend also had the temp control on his Ranger go bad,so meb'be that's it.
Old 06-27-2011 | 05:55 PM
donkersr's Avatar
I have a 1998 F-250. The vacuum motor works on the Blend door. I can't tell where all the other vacuum lines go without taking the whole dash apart.
The temperature control **** resistance varies from 300 ohms to around 5000 ohms.
Old 07-11-2011 | 06:41 PM
donkersr's Avatar
Problems fixed. Turns out I had the Blend door confused with one of the damper doors. The Blend door was broken.
Use Common Sense
06-25-2016 02:30 PM
codyaf
11-22-2010 03:56 PM
CW
04-15-2008 01:05 PM
rob17san
02-10-2006 03:01 AM
Hiram
05-13-2005 04:53 AM
