F250 Dimmer Switch
Old 11-05-2022 | 11:54 AM
HEATHEN0042's Avatar
Default F250 Dimmer Switch
I have an interesting issue and maybe I am just over thinking this. I installed an after market stereo in my 2004 F250. It works great except the dimmer functionality. The illumination wire (lt blue / red) from the truck went to the illumination wire on the new radio but the dimmer functionality is reversed. When i dim my interior lights / cluster, the radio gets brighter. When I brighten my interior lights it gets dimmer. I can bypass this by turning off headlight detection and just manually diming on the radio. I figured I would try here and see if any of you ran into a similar situation. Any help with this or suggestions would be greatly appreciated.
Old 11-05-2022 | 03:38 PM
Just out of curiosity, how is your radio grounded ? I wouldn't go by hoping it is grounded through it's mounting.
Usually they have their own ground wire, and did you connect that to a known GOOD ground?
Old 11-05-2022 | 05:19 PM
The new head unit had a single black ground wire, and that is connected to the black & black and lt green ground wires the factory radio used. Since the after market unit is functioning except the dimming being inverted I assumed it was a good ground, but that definitely gives me something to investigate. For what it is worth i attached the schematics to show you. I spliced the grounds together because i wasnt sure which to use on my one new ground. That may have been a mistake.
The OEM unit had 3 grounds.
The bottom left part of the schematic shows the wire controlling the dimming function.
New unit wiring diagram.
Old 11-06-2022 | 04:38 PM
From a brief look at the diagrams, I suspect you are getting some "feedback" into the interior lighting system.
I believe you are on the right track if you provide "separate " grounding of each system.
Please let us know if separate grounds corrected that alternate path, thanks.
madboat
04-30-2022 03:40 PM
dg7766
09-09-2019 09:42 AM
Christopher Miller
02-24-2018 10:20 PM
Harrygwaii
11-26-2007 06:00 PM
kenny 40ltr
09-17-2005 12:00 PM
Quick Reply: F250 Dimmer Switch
