F250 Fail to Crank
Old 06-17-2011 | 07:37 AM
rolvaag1's Avatar
Default F250 Fail to Crank
My problem is intermittent. I have a 2000 F250 Super Duty. Put key in wait for wait light to go out turn key nothing. All indicator lights on dash light up. No service engine light on.. Might work the following turn of the key might take five turns might work fifteen minutes later. Will not crank in park or neutral. Any suggestions?
Old 06-17-2011 | 09:44 AM
Gary2Wheels's Avatar
check the neutral safety switch...they sometimes become loose and out of correct position...
Old 06-17-2011 | 02:18 PM
rolvaag1's Avatar
I made sure neutral safety switch is tight and the pointers are aligned. Any way to jump out the neutral safety switch?
Old 06-19-2011 | 01:41 AM
I'm not sure of the configuration of the plug that attaches the switch,but I've used such things like a metal paper clip,bent and inserted into the plug supplying power to the n/s switch in order to bypass and test it.
joe ford
08-04-2012 08:22 PM
JB_F250
01-02-2011 11:44 PM
super_f250
01-28-2010 02:29 PM
fishfun83
01-04-2010 10:55 PM
