F250 gear problem
Old 09-01-2011 | 07:54 PM
Mattndahat's Avatar
Exclamation F250 gear problem
My 1987 f250 won't shift out of first gear... its an atomatic transmission and goes till about 25 before sounding hot. what exactly should i do to try and solve the problem???
Old 09-01-2011 | 09:39 PM
I believe the trans in question is a C 6.
You might check the detent (downshift) rod coming off the carb going to the trans.
Also the govenor assy on the tailshaft is either stuck or badly worn.
The gov influences shifting. With a transfer case behind the trans , if its 4 WD can be a little more work to get to the govenor.
Old 09-02-2011 | 03:29 PM
Mattndahat's Avatar
is it a simple fix or something worth replaceing
Old 09-03-2011 | 07:56 AM
You can't just go replacing things until you are sure of what isn't working.
The downshift rod is a simple thing to check.
Seengs
05-15-2011 05:39 PM
Yapalot
04-26-2011 06:29 PM
work_n_progrezz
05-11-2008 11:35 PM
blocker59
05-11-2008 11:34 AM
buffalojump
02-11-2007 08:07 PM
