f350 7.3 tire size
RE: f350 7.3 tire size
Thanks your reply...hayabusa good one ...just bought a bmw k1200r love it...my buddy has a hayabusa...apparantly quite the ride...
I thought of going stock for the milage and the michelin LTX dosen't come in a 285...
jr
99 f350 7.3
98 volvo xc
85 landcruiser
99 grand caranvan 3.8 awd
86 taurus
05 bmw k1200r
98 suzuki 350 dxr
182u cessna
jr
99 f350 7.3
98 volvo xc
85 landcruiser
86 taurus
05 bmw k1200r
98 suzuki 350 dxr
182u cessna
I haven't had a lot of exposure running big tires on these S/D's.. Maybe someone else will chime in.. But, have had plenty of time under the hood, and behind the wheel.. The problem would be where the power/torque to gearing/speed would be, as well as load affects if any.. If you were to run at cruise speeds consistantly, no grades, unloaded, then larger tires 'may' yield a better mileage.. But, most times when I've pulled or driven, the 4R has what I call the 'dead zone' when speed is low (35-45) and the converter locks keeping RPM low, as well as turbo boost pressure/s, and power goes flat and suffers.. So,, the natural reaction is to shove your foot to the floor even harder to bring the power up, or kick down the shift unless OD cancel is selected.. more so with larger tires or load...and IMO would hurt mileage since most owners do a fair amount of city driving.. Plus,,these trucks are like pushing a 8K 'brick' through the air, and if peak power/torque at specific throttle angle/s isn't met more consistanly (think best torque is 1600-1900 RPM, and best peak HP is about 2600) than available power to load to falls off....
I just bought a 1996 F-350. It had 265s on it when I got it, but when I went to Discount Tire, the only thing they would put on it was 235/85-16, because apparently, there is a law about putting only 8 or 10 ply tires on a 1 ton.
I sell tires...and mostly the thing you want to watch out for is speed changes and turning but if you have no problem turning with the tires you have now than you should be fine....the first number corresponds with the width of the tire in millimeters, the second number is the aspect ratio of the tread with in other words sidewall height but a 285/75 is going to be taller that a 265/75 get it but mostly in my understanding of the situation you should be ok
