f350 dually hub bearings
Old 05-02-2008 | 12:11 PM
concrete guy's Avatar
Default f350 dually hub bearings
Hello, I am looking for some advice on replacing the front hub bearings on my 2002 f350 dually.I am hoping that I will be able to replace these myself in the driveway. My questions are:will I need any "specialty" tools for this job? Are any of the pieces pressed on, will it require a machine shop? are there any other reccomended maintenance issues I should do while it is apart? As usual,I appreciate any replies to my questions. Thanks for your time and have a great day.
Old 05-02-2008 | 01:26 PM
david paul's Avatar
Default RE: f350 dually hub bearings
if they aren't bad just repack them
Old 05-02-2008 | 01:29 PM
Hubs as in wheel bearings? 4x4 or 4x2?
Old 05-08-2008 | 05:12 PM
TheQuickShot's Avatar
As far as I know, you can change these very easily in your driveway. You should not need any special tools for this, just the basic tools any garage mechanic should have. While you are at it, you should change your seals. Hope this helps
JARS8078
11-16-2008 11:33 AM
f3504sale
11-17-2007 09:15 PM
The Scientist
07-24-2007 08:28 AM
bluecollar
07-23-2006 02:24 PM
davequest
04-08-2006 12:29 PM
