F350 headlight assembly
I am trying to remove the right headlight assembly on a 1997 F350 diesel. The battery has been removed for access to the back side. I removed the two phillips screws at te top of the bezel. The bezel appears to have the parking and directional assemblys in it. Looking from the back side I can only see one 7-16 nut ,loosened pushes the assembly out on the side towards the center, but the bezel is stil tight on the outside and bottom.
Any suggestions would be welcome.
