Fifth wheel towing package
Overloaded on payload
Mark
I'm not sure what you mean, The Solitude 310GK weight is 12k empty and 15k gross. I understood my towing capacity was 15k so I thought I would be ok? I was planning on installing aftermarket air bags to level out the truck. I have the 6.7. I was more concerned with clearance issues to cab and side rails?
You can find your payload rating on the inside of the drivers door jam. It is a yellow sticker labeled as cargo capacity
Mark
Well that's certainly a bummer. The yellow sticker inside the door says the capacity is only 2,026 lbs. I am sure we were told the payload was 3,450 when we purchased the truck. I was told the only difference between the 250 and 350 was the suspension. I have ordered air lift bags for the suspension, will that make this tow safer?
