Ford F350 instrument panel symbol
Old 10-28-2009 | 08:48 PM
easyriddin48's Avatar
Question Ford F350 instrument panel symbol
On the left hand corner of the instrument panel on my Ford F350 dually a fuel pump symbol with fuel drops to the left intermittently illuminates. I cannot find this symbol in my owners manual or in the aftermarket book I have. I am looking for the meaning of this symbol. Thanks
Old 10-28-2009 | 09:51 PM
Welcome to the site..
Sounds like low fuel warning lamp.. What year is your 350?
Old 09-11-2010 | 01:29 PM
FIF's Avatar
FIF
It is a Water in Fuel indicator, as far as I can determine. Means likely there's too much water in the fuel filter. The diesel supplement owners manual shows how to clear this out.
Old 12-18-2010 | 03:42 PM
Ray H's Avatar
On the fuel line, under the drivers seat on the frame.Take that 7mm plug out and drain it completely, maybe a half pint. Then take a can of throttle body cleaner, with the little red sprayer attached and clean it out. I use Q-tips to wipe it out after I spray it several times until it is clean again. It really gets nasty in there too. Replace the plug and you should be good to go. My truck had the same issues until a Ford mechanic told me how to fix it.
Ray
eagront
02-16-2009 03:43 PM
Num25Duke
09-11-2007 11:28 PM
Num25Duke
09-06-2007 04:19 PM
73markIV
08-30-2007 07:36 PM
stevelad
03-31-2007 10:48 PM
