Fuel pump, 1990 f250 efi 460
Old 03-18-2022 | 07:52 PM
PirateFarmer's Avatar
We can't stop you from spending a lot of $$$ hoping to correct the problem.
What we can do is suggest either you or your mechanic verify there are no opens in the circuit path to the fuel pump. Lets hope that takes care of the problem. If it doesn't ,get back to us and we should be able to assist.
He took out the fuel tank selectoselectch, and it had obvious signs of heat...melted a hole in the side of it. Replaced it with one from my old junk 91 diesel. Now both tanks work, although the fuel gage doesn't, on either tank. It also now pumps fuel from back tank to the front one. I have another friend who is mechanically inclined, and he explained what is likely causing THAT, issue...but for now, I'll just run the front tank and hopefully someone will figure out why the fuel gage doesn't work, anymore.
I do want to thank all of you that offered advice.
Ford xlt 1990
11-14-2021 07:14 AM
redryder51
09-24-2016 07:18 AM
19hec68
09-23-2009 11:53 AM
uncle_mike
10-05-2008 12:22 AM
whozat24450
03-26-2007 02:57 PM
Quick Reply: Fuel pump, 1990 f250 efi 460
