Gear Shift Lock Actuator Bad?
Old 04-08-2008 | 02:09 PM
jon0249's Avatar
Default Gear Shift Lock Actuator Bad?
My 02 F250 is blowing a fuse that controls thegear shift lock mechanism (and also the cruise control). When I start the engine and depress the brake pedal, the gear shift will not move out of Park, so I turn it off, turn the key to the first position to unlock the steering wheel, shift to Neutral, start the engine, then move into Drive. With the engine running, in Park, I can manually depress the spring-loaded key that allows the gear shift lever to move out of Park (without depressing the brake pedal), so I'm thinking that the solenoid that is actuated by the brake light switch is bad. However, in my mind, this should not result in a direct short/blown fuse condition. What is going on?? Is this a recurring problem with this model?
Jon - Dallas
rlpatte
03-31-2012 09:45 PM
Yapalot
04-26-2011 06:29 PM
BelowJon
07-02-2008 09:57 PM
tommyp35
04-05-2007 05:48 PM
jpbucher
03-04-2006 07:44 PM
