heater core
Replacing the heater core in a Ford truck..EZ
Replacing the heater core is easy but a bit time consuming. The glove box must be removed, both coolant lines to core and disconnect the electrical connections, The core is held in position with 2 small brackets. Some manipulation is required but a very easy task. The new cores are about $30 at the discount parts stores. Check coolant color and replace as necessary, and use distilled water mix. Frank...........Idaho
"Cheap" car parts
Most parts are made to satisfy some minimum requirements. Bad parts are mostly a defect in the making process and get past the inspectors. The replacement heater cores are the exact duplicate of the factory parts. I have replaced many Ford heater cores with not a single failure. After replacing several cores, the task becomes very simple and easy. It seems as the today parts are engineered for a part failure at a predetermined time or mileage. In tank fuel pumps must be the number one failure part.. Frank
09 6.4 has to have the the complete heater core/evaporator case removed from the dash. Instrument panel removed, A/C evac, etc.. Large job,, and does require a few specialized tools, quick release tools for hose connections etc.
ericftz
09-03-2005 09:02 PM
