Help! 6.0 wont start
Old 05-27-2013 | 12:41 AM
Later 6.0's have the ICP in the passenger/right valve cover forward area. 3 wire, and tested/probed connected, and with a hard/no start KOEO during tests..
One circuit will be a reference voltage right around 5v, one will be a ground, and the 3rd will or should test at about 0.08 volt 'cranking' (0.08 for 500lbs for a start pressure)
  #12
Old 05-29-2013 | 06:57 PM
banders's Avatar
My f-250 is an 03, went back to post #1 and realized I put 06. Sorry! I read on this truck its in the back, driverside between motor and firewall, hard to get at, and has 3 wires. believe its the right plug. tested all possible contact points, ( outside and inside plug) did not crank motor during test. Should I have? Is that what KOEO means?
adam
07-29-2010 02:04 AM
explodegirl
07-01-2008 11:12 AM
cesar huerta
06-01-2008 07:38 PM
sphinx91
02-15-2008 01:15 PM
salem503
01-26-2006 03:54 AM
Quick Reply: Help! 6.0 wont start
