Hey HAYAPOWER ? for you
Old 01-22-2007 | 09:46 PM
wheelsup68's Avatar
Default Hey HAYAPOWER ? for you
I'm working on a 2001 F-250 superduty that will crank no start. I have not seen any fuel pump failures from these trucks in 5 years, bu this model (5.4) triton has no fuel pressure and I can make it run on Ether. It provided me with a trouble code OBDII that was po232 Fuel Pump Secondary Circuit High. Is this a relative code to the fuel pump being bad, or is it a problem elsewhere with wiring or something? Any feedback would be helpful since I would rather be safe than sorry. I really trust your opinion, and would like to do this once. If there is a particular flowchart I should follow let me know.
Old 01-23-2007 | 12:54 AM
Default RE: Hey HAYAPOWER ? for you
Sent you a PM
Old 01-24-2007 | 12:02 AM
wheelsup68's Avatar
Well I checked out the inertia switch, and did a pin test b4 I removed tank completely. What do ya know it ended up being the fuel pump. Just don't see that much in the full size trucks. Oh well I guess there is a first for everything.
Old 01-24-2007 | 03:06 AM
Higher mileage truck?
I'drather replace a pump or other component that shake down a wiring problem...
Old 01-24-2007 | 10:43 PM
wheelsup68's Avatar
Truck had 150k on it, and I agree much better to do pump than anything electrical related.
darylsr
01-22-2009 12:07 PM
FordLover1963
11-18-2008 08:05 PM
cdlray
06-19-2008 07:00 AM
wheelsup68
11-27-2006 03:06 AM
Quick Reply: Hey HAYAPOWER ? for you
