Instrument cluster failure
Old 09-24-2007 | 06:51 PM
Mikey_likes_it's Avatar
Default Instrument cluster failure
Today when I was at a stop light I pushed the tow button to disengage the overdrive and in doing so my instrument panel went dead like I turned the key off. I have checked all the fuses that pertain to the cluster but none were blown. Any idea what could have happened. Truck still runs without instruments.
2004 F-250 super duty crew cab 5.4
Old 09-27-2007 | 02:12 AM
Beater's Avatar
Default RE: Instrument cluster failure
Check for TSB's on your truck. My 06 had a TSB on it and Ford replaced my instrument cluster after it quit working.
Old 09-28-2007 | 05:41 PM
What is a TSB?
I have found the fuse that keeps blowing (#45) and have replaced it only to have it blow again. Reading the manual I would have never found the fuse because it says # 45 is for something completly different. I will be taking it in to the shop to have it fixed under warranty.
Old 10-02-2007 | 05:11 AM
Beater's Avatar
Tech Service Bulletins. You can find them on this forum at the top of the page.
JMAC85
02-21-2011 11:58 AM
mrcol
07-09-2007 09:58 PM
sisdavid@yahoo.com
08-09-2006 12:32 PM
gpressick
07-14-2005 07:05 PM
jtt3769
06-04-2005 01:12 AM
